Lincoln Forum: 05 navi rear airbags stuck in up position please help
Results 1 to 2 of 2
  1. #1
    Join Date
    Mar 2017
    Posts
    Remove this ad
    So I went and got new tires today and turned the suspension switch off prior to shop lifting truck up. Installed new tires turned switch back on when I left, drove great for 10 or so miles than rear suspension aired all the way up and now it will not deflate.
  2. #2
    Slick Fan's Avatar
    Slick Fan is offline Senior Member My Lincoln(s): 2003 TC Signature, 1977 TC, 2003 Aviator
    Join Date
    Jan 2014
    Utah
    Posts
    329
    Remove this ad
    Sounds like the ride height sensor on the rear axle may have been bumped off it's mount. If it looks undisturbed, you may need to replace the sensor.
    Welcome to the forum!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
