Lincoln Forum: 2010 MKZ Chaged Engine Air Filter (forgot to plug in MAS/F sensor cable) NOW CEL ON!
Results 1 to 2 of 2
  1. #1
    Join Date
    Nov 2016
    Posts
    21
    Remove this ad
    Well just did the above, started the car after I inspected the engine air filter and saw the CEL on so I drove turned off the car and plugged the sensor back in. Then took the car for a couple mile ride and the CEL light is still on.
    Question is will this re-set it self w/ more miles? Or do I have to hook it up to a OBDII scanner and reset it that way???
    TIA
  2. #2
    Join Date
    Nov 2016
    Posts
    21
    Remove this ad
    Quick update, the fix was simple. Disconnect the neg post of battery , wait a minute and reconnect. Fixed
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
