Lincoln Forum: 1998 4.6l Lincoln Town Car Executive 193,524 Mi $1000 OBO
Results 1 to 9 of 9
  1. #1
    Join Date
    Dec 2010
    Posts
    9
    Remove this ad
    Known problem components for this model have been replaced:
    1) The original rear suspension air lift systems on these cars often fail and are VERY expensive to repair. This one had the problem and was replaced with normal spring system, as is most often the best option.
    2) The original intake manifolds on these are also known to be a problem. This one was replaced with the new improved version with a metal crossover for the front water jacket.
    New plugs, one bad injector replaced, starts good runs good except does not respond well with the foot slammed down. I'll be looking at the MAF and TPS for that problem.
    Heater works, AC does no. I will look at the AC as well.
  2. #2
    Join Date
    Dec 2010
    Posts
    9
    BTW, this is in Brazoria County Texas, south of Houston.
    Got a P0358 on cylinder 8 probably at least part of the acceleration problem. Should be easy enough since it's a COP circuit problem. Connector, coil or wire most likely. I will fix that.
  3. #3
    Join Date
    Dec 2010
    Posts
    9
    Still not had time to fix COP Circuit problem, wife sick.
    Will take $800
  4. #4
    Join Date
    Dec 2010
    Posts
    9
    Accepting offers again
    Had an offer of 850 that was rescinded by the potential buyer before looking at the car. I believe it was financial strife or maybe they found another they liked better.
    Regardless, available for offers. I will deliver within a reasonable distance and time frame.
    I fxed the spark plug circuit problem. It was simply a bent in on the coil connector. She runs much better now!
  5. #5
    Join Date
    Dec 2010
    Posts
    9
    No enthusiasts in my area?
  6. #6
    Join Date
    Dec 2010
    Posts
    9
    bump, looking for somebody in the Houston area
  7. #7
    Join Date
    Dec 2010
    Posts
    9
    Have two different buyers coming by tomorrow.
    Go Coogs and Go Elandon Roberts, Sebastion Vollmer (Injured) NE Pats
  8. #8
    Join Date
    Dec 2010
    Posts
    9
    Sold pending transaction, will mark sold when done this evening.
  9. #9
    Join Date
    Dec 2010
    Posts
    9
    Remove this ad
    Was Sold tonight
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Genesis Motors
