Lincoln Forum: Removal of the Map Light Assemble
Results 1 to 3 of 3
  1. #1
    Petec is offline Junior Member My Lincoln(s): 2014 MKX
    Join Date
    Jun 2016
    East Amherst, NY
    Posts
    11
    Remove this ad
    Does anyone know how to remove the map light assembly? Specifically for a 2014 MKX but any model or year may be a help.
    I want to pick up power from the assembly.
    Thanks,
    Pete
  2. #2
    Join Date
    Oct 2014
    Posts
    17
    Realize this answer is a little old, but for anyone else you just pull from the back edge (the end nearest the windshield). With your fingers pull down the back and out.
  3. #3
    Join Date
    Jun 2016
    East Amherst, NY
    Posts
    11
    Remove this ad
    Thanks enigma-2.
    I ended up running a seperate wire from the fuse box. It is well hidden but your solution would have been better.
    So I just yank on it. Interesting. With my luck it will crack.
    Thanks again,
    Pete
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
