Lincoln Forum: Cabin Air Filter
Results 1 to 5 of 5
    Jun 2015
    Cabin Air Filter
    Okay, I know where the cabin filter should be and I have a replacement. But the door does not exist, it is a solid piece plastic. Can I cut that out a install a filer? There is an odor when I turn on the AC and hope this would make it better. I do not want to cut out the panel/door if a filter will not slide in.
    Rongold's Avatar
    Rongold is offline Member My Lincoln(s): 2014 MKS, 2015 MKS
    Apr 2016
    Putnam Valley, N.Y.
    70
    52
    Cabin filter location
    What year is your MKS---We can't read minds. Where were you looking ??? FILL OUT YOUR PROFILE !!!
    Aug 2016
    There is nothing to cut. I'm thinking there might be a tab release. Due to change mine again but I forget what it looks like.
    iBuyHouses is offline Junior Member My Lincoln(s): 2011 MKS
    May 2017
    Valkaria, FL
    4
    https://www.carcarekiosk.com/video/2...er_cabin/check
    I remember thinking the same thing after watching this video. When I took a closer look, I could see that there were tabs that needed to be released to access the filter.
    Dec 2016
    5
    Just changed in MKT .
