  • Car enthusiast? Join us on Cars Connected! iOS | Android | Desktop
Lincoln LS Automatic Temperature Control Self Test
The 2006 LS has a dual automatic temperature control system that can be accessed through a self test procedure to identify certain problems in the HVAC. The explanations for the DTCs reported can be found in the attached documents in Word and PDF formats.
2006 Lincoln LS DATC self test
Front Panel DATC Module Self-Test (On-Demand Diagnostic Trouble Codes — DTCs)
On-demand DTCs are those that are reported by an ECU when a failure is detected while executing a diagnostic test. For the DATC module this means that all faults (hard) that occur while the module is conducting a self-test shall be reported as an on-demand DTC.
• The DATC module self-test will not detect concerns associated with data link messages such as engine coolant temperature or vehicle speed signals. The diagnostic tool must be used to retrieve these concerns.
• The vehicle interior temperature should be between 0-32°C (32-90°F) when carrying out the self-test. If the temperatures are not within the specified ranges, false temperature sensor DTCs may be displayed.
The DATC module self-test through the front panel display:
• can be initiated at any time. Normal operation of the system stops when the self-test is activated.
• is entered by pressing the OFF and DEFROST buttons simultaneously and then pressing the AUTO button within 2 seconds. Record all DTCs displayed.
• concludes by reporting all on-demand DTCs. Follow the diagnostics procedure given under ACTION in the DTC index for each DTC given.
• reports individual on-demand DTCs as 4-digit DTCs (less the alpha character).
• will calibrate all the mode doors and check all analog inputs. The DATC module will only report on-demand (hard) faults that occurred while the DATC module was conducting its self-test.
• will light all control panel display segments if no faults are detected.
• will report individual on-demand DTCs without the °C symbol lit.
To exit the self-test, press the DEFROST button. This will clear all on-demand codes from the DATC module memory. If no button is pushed, DTCs will continue to be displayed.
Upon exit from the self-test the DATC module returns to operational status. The DATC module executes a hard (cold boot) reset which places the DATC system in the OFF mode.
Always exit the self-test before powering the system down (system turned OFF).
Front Panel DATC Module Display — Retrieve Continuous Diagnostic Trouble Codes (DTCs)
Continuous DTCs are fault codes recorded by the DATC module which have occurred during normal operation. For the DATC module this means that all faults (intermittent or hard) that occur while the module is in an operational state shall be reported as a continuous DTC.
• To retrieve continuous DTCs, press the OFF and DEFROST buttons simultaneously, followed by pressing the RECIRC button within 2 seconds.
• The DATC module will report all continuous DTCs to the vacuum fluorescent (VF) display.
• The DATC module will not carry out a self-test; it will only display continuous faults codes which are stored in memory.
• All VF display segments will light if no faults are detected.
• Individual continuous DTCs will be reported with the °C symbol lit.
• DTCs shall be reported as a 4-digit DTC (less the alpha character).
• Pressing the front DEFROST button will exit the retrieve continuous DTCs mode and clear all continuous DTCs from DATC module memory.
• Pressing any other button (other than DEFROST) will exit the retrieve continuous DTCs mode and maintain all continuous DTCs in DATC module memory.
• Upon exit from the retrieve continuous DTCs mode the DATC module returns to operational status. The DATC module executes a hard (cold boot) reset which places the DATC system in the OFF mode.
2000 LS DATC self test
The HVAC on the 2000 LS is controlled by the Dual Automatic Temperature Control (DATC) module. This module has a self test feature that will display any diagnostic trouble codes (DTC) on the display screen so that any problem can be addressed.
Front Panel DATC Module Self-Test (On-demand Diagnostic Trouble Codes—DTCs)
l The DATC module self-test will not detect concerns associated with data link messages such as engine coolant temperature or vehicle speed signals. The scan tool must be used to retrieve these concerns.
l The vehicle interior temperature should be between 0-32ºC (32-90ºF) when carrying out the self-test. If the temperatures are not within the specified ranges, false temperature sensor DTCs may be displayed.
l can be initiated at any time. Normal operation of the system stops when the self-test is activated.
l is entered by pressing the OFF and FLOOR buttons simultaneously and then pressing the AUTO button within two seconds. The display will show counts of 1 to 25 in the center of the display window. Record all DTCs displayed.
l concludes by reporting all on-demand DTCs. Follow the diagnostics procedure given under ACTION in the DTC index for each DTC given.
l reports individual on-demand DTCs as four-digit DTCs (less the alpha character).
l will calibrate all the mode doors and check all analog inputs. The DATC module will only report on-demand (hard) faults that occurred while the DATC module was conducting its self-test.
l will light all control panel display segments if no faults are detected.
l will report individual on-demand DTCs without the ºC symbol lit.
To exit the self-test, press any button. This will clear all on-demand codes from the DATC module memory. If no button is pushed DTCs will continue to be displayed.
If a condition exists but no DTCs appear during the self-test, refer to the Symptom Chart Condition: The DATC System Is Inoperative, Intermittent or Incorrect Operation.
Front Panel DATC Module Display—Retrieve Continuous Diagnostic Trouble Codes (DTCs)
l To retrieve continuous DTCs, press the OFF and PANEL buttons simultaneously, followed by pressing the AUTO button within two seconds.
l The DATC module will report all continuous DTCs to the vacuum fluorescent (VF) display.
l The DATC module will not carry out a self-test; it will only display continuous faults codes which are stored in memory.
l All VF display segments will light if no faults are detected.
l Individual continuous DTCs will be reported with the ºC symbol lit.
l DTCs shall be reported as a four-digit DTC (less the alpha character).
l Pressing the front defrost button will exit the retrieve continuous DTCs mode and clear all continuous DTCs from DATC module memory.
l Pressing any other button (other than DEFROST) will exit the retrieve continuous DTCs mode and maintain all continuous DTCs in DATC module memory.
l Upon exit from the retrieve continuous DTCs mode the DATC module returns to operational status. The DATC module executes a hard (cold boot) reset which places the DATC system in the OFF mode.
"2000 ls v8" this may be a silly question, when they say floor buttons do they mean press both defrost floor and windsheild defrost buttons? When i tried nothing happened.
Welcome ahill007ny,
There are no silly questions. No they don't mean multiple floor buttons. It would have been clearer for Ford to have said: Press the OFF button and the FLOOR button simultaneously and the AUTO button within 2 seconds.
Hi, I have a question. Do I have the car running or shut off? Do I turn the a/c on before I push and hold the buttons? Do I turn the key to the on position and then run the diagnostic?
I did something and got these numbers 12 62 27 99 I have no idea of what I'm doing- I just bought the car last week and heat is coming out when I put the a/c on, no matter what I do. I disconnected the negative side of the battery to see if that cleared it, but nothing. Thanks in advance for any help.
Rick
I am having trouble try to get the tested startef
