Lincoln Forum: Coolant Bleeding
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Join Date
    Jan 2013
    Posts
    Coolant Bleeding
    Remove this ad
    Originally the vehicle was not heating up properly, so I thought maybe it had one of those garbage fail safe thermostats that got stuck in the open position. So, I replaced the thermostat today, only to find out that the old one was functioning properly when tested. Which leads me to believe the person who had it did not bleed it properly when replacing the coolant. It was a real bear getting the T-stat housing off and what not, but now its done and I'm ready to add coolant. I can see what looks like a bleeder screw on the top metal cooling pipe. It looks like it can be removed with a small ratchet. The issue I am having... I've broken two ratchets trying to get the thing off! I don't understand why it would take so much force to remove it, its just a bleeder valve, most cars just require a screw driver for removal with minimal force needed on a little plastic fitting. Is it common for this to happen? Just looking for advice and appreciate any input. Thanks!
    Vehicle is a 2004 Lincoln Aviator
  2. #2
    driller is offline Senior Member My Lincoln(s): 2010 Limited Edition Navigator L, 2006 Designer Series Town Car, '98-'96-'93 Mark VIII's
    Join Date
    Jul 2009
    Morgantown, WV
    Posts
    256
    A pic would really help.
    I don't know bout the Aviators, but the Mark VIII's have a history of the cap on the coolant crossover tube seizing up. You cannot burp the coolant system properly without removing the cap. If the valve you speak of is indeed a bleeder valve for the coolant, likewise it will be nearly impossible to properly bleed air from the coolant system.
  3. #3
    Join Date
    Nov 2007
    Fort Wayne, IN
    Posts
    2,882
    I don't think I've ever heard of a bleeder valve on the coolant system. I thought that's what the radiator cap or coolant reservoir cap was for?
    Nick
    Past: 1967 Lincoln Continental convertible, 1987 LTC Cartier, 1996 LTC Signature, 1996 LTC DAE, 2002 LS V8, 2006 Zephyr, 2010 MKZ AWD
    Current: 2009 F-150 Lariat Supercrew 4x4
    WANTED: 1967 Continental sedan or convertible
    In my dreams: Continental Mark II
  4. #4
    Join Date
    Jul 2009
    Morgantown, WV
    Posts
    256
    It's a DOHC thing.
  5. #5
    Join Date
    Jan 2013
    Posts
    I did get it off. Took a blow torch to it, came right off the 3rd try. Sorry for the confusion, its a bleed "cap" that sits on the top radiator hose. It seems to be getting to temp properly now, still a tad cool though...
  6. #6
    Join Date
    Jan 2014
    Posts
    7
    Hello
    I have the same problem, I have a lincoln continental 98. I can not open the bleeding cap, I am attaching photos. I was thinking taking out with a torch but just in case and the end I will need to replace it. somebody know the exactly name of the "cap" and where can I buy it. so far I tried bleeding cap, bleding valve, threaded plug . And nothig but the pics show want I mean
  7. #7
    Join Date
    Jul 2009
    Morgantown, WV
    Posts
    256
    I've used a propane torch carefully on the side of the tube just below the lip of the plug with a large pair of channel locks on the top edge of the plug.
    In worse case, you can have a nut welded to the top go the plug and use a regular box wrench to remove the stubborn plug.
    There is a plug for sale on ebay.
  8. #8
    Join Date
    Jan 2014
    Posts
    7
    Hello Driller
    Thanks for your answer,do you have the ling about the plug on ebay. I was trying to find it with different names but not lucky. Or what name do you use for searching on ebay?
    BBL
  9. #9
    Slick Fan's Avatar
    Slick Fan is offline Senior Member My Lincoln(s): 2003 TC Signature, 1977 TC, 2003 Aviator
    Join Date
    Jan 2014
    Utah
    Posts
    261
    Quote Originally Posted by Marcajirca View Post
    Hello Driller
    BBL
    Click on his "Ebay" word, for the link...or here's the same link in long form.
    http://www.ebay.com/itm/96-98-99-01-...dcf26e&vxp=mtr
  10. #10
    Join Date
    Jan 2014
    Posts
    7
    Remove this ad
    wow thank a lot for the link. Do you know if Mark VIII and Continental have the same engine. I wonder if this cap will fit my lincoln continental 98
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
